Next Project
Calhere
Re: Next Project
Nice looking project. Classic lines, lapstrake hull (ride like they are on rails). And it looks like the original windshield was a square corner, not a wrap around style. Not too hard to make from aluminum L or U channel and plexyglass.
Might I recomend mounting the seats a little low, for a more sporty feel, and make the windshield a little taller, so the wind goes over your head, not right into your eyes.
The gelcoat looks faded, but if your look at my MFG project in my signature below, you can probalby polish the original red color back. And don't think you have to polish it, you can sand it, prime it, and have the local body shop shoot a nice coat of auto paint on it that will hold up just fine for years.
BTW, the control box is a great one. Not hard to disassemble, lube it up and clean any electrical connections on the switch. Ask when you get to that point.
Make a list of all the accessories you want, like gauges, new steering helm and cable, gas/water filter, permanent tank, new seats, etc. Price it all out so you get no surprises. I bet you can't buy a new boat of that size for what it will cost to get that one cleaned up and running like a top.
Good luck, and keep us posted on progress. Its a nice looking boat.
About the paint being faded this stuff pulls off miracles http://www.westmarine.com/webapp/wc...true&storeNum=163&subdeptNum=164&classNum=164 1 or 2 cotes then a wax and my paint looked fresh.
EDIT
on second look maybe a new paint job is needed.
Mark42
Re: Next Project
Was the cap painted with spray paint cans? Looks like it from the photos. Probably the best solution is sand and paint.
JaSla74
Re: Next Project
Did you ever get the rest of the old floor out, or do you plan to leave it & lay the ply over it? If you haven't I'd pull the rest out, I mean you've come this far why not?
proshadetree
Re: Next Project
Id pull all that wet nasty mess up its just going to cause problems later.you almost to the rebuild part Keep it up and you will be floating soon.
Calhere
Re: Next Project
I agree that rotted wood will only spread to the new wood you put down.
zach103
Re: Next Project
all the wood is up.. well except for the transom but im workin on that .. its now down to fiberglass.. but the fiberglass isnt flat and even .. its all bumpy like an old dirt path lol.. so thats why i wondered if i should just lay the wood on top of that.. .. yah the pictures bad it was at night
zach103
Re: Next Project
yah mark it was lol.. my work when i was about 12 years old lol.. ill most likely go with Perfection later on
Willyclay
Re: Next Project
Glad to see you posting again. Hang in there with the project. Most forum members have time constraints of one sort or another. It's like eating an elephant: You gotta do it one bite at a time!
A suggestion regarding storing the cap until you get around to re-installing it. Your last pictures showed it elevated on sawhorses forward and aft. Any pressure on it like snow, wind or someone's elbow is likely to break one or both the side/gunnel sections. That would only add to your repair list. I recommend that you store it on the ground with bracing only where needed to maintain the original lines and prevent stress points. Good luck!
zach103
Re: Next Project
good thinking.. how much do you think it weighs.. i was thinking about making it so that i can drop the cap down from the ceiling and work on it when i want.. than i can do all the electrical and everything from under it
zach103
Re: Next Project
anyone got any ideas on how i can get it so that i can lift the cap up so i can work under it
zach103
Re: Next Project
im in a shed now so i have a number of 2x6s running along the roof that i was trying to use..
i got some glass done today. trying to fill a few holes.. i need to lube up steering wheel and get it off.. than a good layer of glass on over the whole dash. new wood on the back of it... than trailer work
zach103
Re: Next Project
still need some help with being able to fit the cap.. anyone have any ideas??
zach103
Re: Next Project
wow been awhile.. but i started goin again
oh and my new radio for 25 bucks
jcsercsa
Re: Next Project
Hay there Zach ,
Did you try to get her out yet ?? Today would be a good day to try !! its going to get 41 here today , then cold again tomorrow !! If you can get a hose out there it should do it !!! John
Ps great find on the radio !! find me one !! lol
zach103
Re: Next Project
ill keep looking lol
no not today.. im gunna try tomor if i can get out of work early enough
zach103
Re: Next Project
well went after work. 3 hoses couldnt get any water thru them i think one of them has ice in it.. so got frustrated and was about to go home when i slid a little on some ice and grabbed the boat to help. and the boat moved lol. it got up to 50 today but no sun so didnt feel that warm but just enough to thaw the ground some more just enough.. so went home finished the trailer . headed back over around 830 and now the boats on
