Next Project...
andgott
Though I'm only about 1/3 done with my current project, the NEXT boat is already sitting in the basement waiting it's turn- a 1961 Custom Craft Tiger Ray.
It was one of those things I couldn't pass up. Someone hears you are working on an old boat, and comes to check it out. They mention that they've got a project boat that they've been meaning to start, but never got to. Then, I found out that it's a pretty rare find.
It's got EVERYTHING that a '60's boat should have- Fins, Fake Taillights, and 'side scoops'.
Check out the transom-
Those 'tail lights' and fins don't serve any purpose other than to look cool...
The prior owner had started the restoration by cutting the trasom cap and motorwell off, to avoid separating the hull and deck. Hopefully I'll be able to do the rest of the work without removing the deck- It's stapled to the hull- and would be a LOT of work to get apart!
And, Check it out from the bow-
I think it's got some pretty cool lines.
Here is the 1961 brochure, showing how it looked in it's glory days-
The plan is to restore it to original condition, just like the Glasspar... Yes, it does need a LOT of work- But that's 1/2 the fun.
There will probably be a few modifications done- First, The transom is set up for a 15" shaft motor, and I'll probably be raising it to accommodate a modern, Long shaft motor. This will give me FAR more power options.
Also, the bottom of the boat never had stringers- It was stiffened with plywood panels glassed in place. These are, of course, rotten. They will be replaced, but probably either with balsa or foam rather than ply. Any thoughts on this??
-Andrew
vegasphotoman
Re: Next Project...
really neat.....
Andrew how's the gel coat ? is it all crazed and cracked.?
looks good in the pics
Do you have the windscreen?
Fun stuff! thatl be a sharp little runabout when your done!
archbuilder
Re: Next Project...
Wow that is a cool boat! Keep up posted....I can't wait to see that one on the water!
Captmills
Re: Next Project...
Don't ya just love those tail fins on a boat???
BobsGlasstream
Re: Next Project...
Captmills,
That's a wild looking shape on the front profile.
I also looks like you will have your cut out for yourself.
I have been thinking about my next project, but I have got to keep it to myself. My beloved would kill me. :redface:
Should look pretty cool on the water.
Bob
archbuilder
Re: Next Project...
I think it looks like the Starship Enterprise from the front.....way cool! I bet you don't get lost in the crowd at the lake! LOL!
andgott
Re: Next Project...
She'll be a big project- But a fun one, too. It's actually in a little better shape structurally than the Glasspar was when I started her. The biggest job is going to be removing the plywood core material from the hull and replacing it.
I have the motorwell section that was cut out to get to the transom- The guy did a great job with it, it's a good clean cut that'll be easy to put back in place once the new (higher!) transom is put in place.
A small number of these boats were built with a cool, sliding 'half hardtop'. As far as anyone knows, None of them survived, but other models by the same company had pretty much the same tops. I am thinking about fabricating one, I played with it in photoshop (using a photo from another model built about the same time) to see what it would look like-
really neat.....
Gel-Coat on the decks is a little on the rough side- It'll need to be painted. The hull is pretty decent- No cracks or crazing- So I should be able to wetsand & buff it.
Yup- I actually have an original, NOS windshield from when the company went out of business in the 60's! They ended up at a marina, and were sold off gradually over the years. Someone found them, and bought the whole lot. There was only ONE left for this model boat. Now, All I have to do is get to Buffalo to get it!
archbuilder
Re: Next Project...
Very cool, I say make a reproduction of the hard top!
evildocrsx
Re: Next Project...
That is an awsome boat. Have you decided how much power you're going to hang off the back.
andgott
Re: Next Project...
Thanks.
I'm not sure about power yet. The Manufacturer rated it for 200 HP- But that's on the generous side, for sure! I'd be afraid to put much more than 100 or so back there. I've got PLENTY of time to worry about power while I get the work done on my current restore... And this one. It'll be a while :)
ljc1957
Re: Next Project...
You have to put functioning brake/tail lights on that boat. Cool looking boat.
jcsercsa
Re: Next Project...
Too Cool !! nice find !! welcome to the MBS there is no cure as we know of yet , but the Doc, are working on a ebay block and craigs list block but the hard one is the blinders on while driving !!! lol John
bananaboater
Ensign
Re: Next Project...
200 HP! 100HP! Yikes :D
Will it have airbags and seat belts?
Great looking boat. I'm a sucker for fins and boats with them.
albert
andgott
Re: Next Project...
Thanks.
I've suffered from MBS for a LONG, LONG time. When it was at its worst, I had 3 sailboats, one of which I lived on, 2 power boats, a kayaks, and an inflatable dinghy. All were in the water, too. I rented 3 30' slips at the marina to fit them all. Luckily, I worked at the West Marine right across the street, and I got a good discount on all the 'stuff' I needed!
I thought that I was cured, then I had a relapse... Brought on by Craigslist... But- Craigslist wasn't enough- I then discovered Craiglook. The ability to search craigslist nationwide is what threw me over the top...
Yeah, I think that 200 HP is perhaps excessive... 100 is probably a bit much, though the transom is (or WAS) pretty beefy in this boat. I think that the excessive HP ratings from the builder might have contributed to the rarity of these boats today- Drop 200 HP her, and I don't think she (or YOU, for that matter!) will be long for this earth. I'm probably going to go safe, somewhere in the 75 HP or so range. That'll push her along.
andgott
Re: Next Project...
When I get bored & I'm away from my boat projects, I break out the Drafting tools!!
I took a number of measured photographs when I was home, And have been working on scale line drawings of the boat. I'll use them to plan out the interior, as well as the proposed hard top addition-
You don't really appreciate how truly unique the lines of this old girl are until you try to put them on paper :)
-Andrew
bman1bpm
Re: Next Project...
Cool boat! Now you just need to fix up a 57 chevy to pull it!
andgott
Re: Next Project...
After speaking to owners of these (and other boats from the same builder), I've come up with an "attack plan" that should get her back to better than new, while still looking more or less factory-
Here's how it looks now-
The dark area on the bottom of the hull is a previous attempt at repair. The original boats were built with a layer of plywood laminated in to them, and no stringers. The wood rotted, and some previous owner decided to add another layer above it for strength. They nailed it with roofing nails to the ply below it, then put a layer of CSM on top, wetted out with resin. Well, Of course, this failed- The new ply that they put in there is all rotten. Luckily, it comes out easily!
New forward seat platform- This is 'factory'-
And, A new floor. This is not quite how it was done, but will result in something that looks the same, but should be a lot stronger-
The orange down the middle is a stringer- The original boat didn't have any, the plywood floor went all the way across, supported only by foam. The yellow is foam... There is new ply in the bottom, where the old ply was....
Now, the new transom Raised 5" to accept a 20" rather than a 15" motor-
This is the biggest modification to the boat- But it looks like I can do it without changing the looks too much. Most important- it doesn't affect the fins at all!
And, of course, the seats, dash, and windshield!
BobsGlasstream
Re: Next Project...
andgott,
Extremely cool ideas. That boat should turn some heads. :D
Can't wait to see your progress. :p
Bob
