Motor had been sitting for 2 years. I had an issue starting her up, had primed gas bulb nice and tight but when cranked no fuel/no fire... Sprayed some gas/oil mix into piston#1 and she fired. Alright, I was recommened to clean out and replaced the gaskets on all three carbs. Done.. Redid the fuel pump with the valve kit and water impeller,too. This is what happened next, moved warmup control up all the way, turned key, pressed the choke button and all she did what turn and turn and turn.. Looked over the warmup cable to see if it turned anything in the motor, nothing.. adjusted as best I could the cable and still no response. Went back to spraying some gas into piston#1 and she fire up and revs up since the warmup control was up.. starting easing the warmup control back and half way she starts to sputter and when I move the warm up control back to where it supposed to be she she stops running....? The only way to keep her running is if I have the warmup control half way or 3/4 engaged. Any idea what to do next??? Also something to is that when she begins to want to go if I have the choke pushed in (I'm guessing when this happens I didn't need to choke) the motor stops turnning and makes a funny squelling noise and also hear something spinning... I wait for the spinning to stop and she starts without the choke.. I know of a idle stop screen that I saw and I know each of the carbs have an idle mix screen but did not want to mess with anything until I was able to get someone's opinion on this..? (btw when running she peed just fine)..Also I noticed that I have no throttle stop screw...would this cause so issue too?
I know there's alot of question all in there but I all new to this and just trying to get her started up myself before paying the $70 shop per hour fee..
Thanks in advance for your assistance..
