ngk plug comparrison
sutor623
Re: ngk plug comparrison
What motor? Just use what it calls for, its all about the temperature of the plug.
fishlips69
2005merc 50hp 3cyl 2-stroke merc shop manual lists bp8h-n-10/bpz8h-n-10/buz8h/bp8hs-10 all same heat range 8 wondering which one would be best. pushing 18ft pontoon
oldman570
The only differance between them is the material that the plug is made from. Same as a Champion L78 and a L78 platium plug only diffrent brand. The BP8H-n-10 will cost less and is up to you as to how much you want to spend. As long as the motor was running fine with the old plugs, then I would use a new set of them to replace the old ones with. I always carry a extra set of plugs on the boat just incase one dose go bad and I have one to replace the bad one with then. Saves the day and money in the long run also. JMO
Oldman570
