I just recently picked up a 98 Nissan 15hp engine. The engine has been sitting almost all of its life... I took it out, and was surprised at how well it ran for sitting so long!
I have a couple of questions;
1. I need to raise the motor an inch or two on the transom, and don't see any obvious adjustments on the bracket to raise, only to tilt. Is there no easy way to adjust the height?
2. I see 3 wires (black, yellow, white) coming from electrical, not connected to anything. What are these for?
3. I'm going to change out the impeller this weekend. Is there anything else I should check or do while I'm in there? Are there any other seals or gaskets I should get besides the impeller?
Thank you
Thank you
