Nissan 3.5hp
pscrabber59
Just bought a used Nissan 3.5Ahp motor. Want to change-out the spark plug, water-pump(impeller) before i take it out on the water. PO said it is a air-cool engine but i think it is water-cool but whatever when starting the motor it stars in gear(direct drive?) there is no F-N-R gear. My question is there a impeller in the shaft or behind the prop? I'm used to larger motors when changing the water pump. Thanks for any help/advice.
pvanv
PO was mistaken (or just an idiot). The water pump runs on the prop shaft. [h=5]IMPELLER : 2.5/3.5A 2-STROKE[/h]
Description Impeller only.
Fits:
2.5/3.5A & A2 2-Stroke models
Part #: 309650211M
List Price (MSRP): $18.68
[h=5]NGK BP6HS-10 : FITS 2.5/3.5 2STR[/h]
Description NGK BP6HS-10 Spark Plug
Fits 2.5hp & 3.5hp 2-stroke models
Part #: 970101011M
List Price (MSRP): $3.20
pscrabber59
Thanks Paul for the info. Gap setting would be .04 on that plug?
pvanv
Check your owners manual, available online at nissanmarine.com. Spec is 1.0 mm. Thats about 0.040". There is usually a sticker on the motor showing that.
