Nissan 70
jcadu837
Bought a new nissan 70 horse non TLDI. After the normal break in engine begins to stutter and lose RPM's. Alos begin to hear a rattling noise coming from the engine. Only happens when in gear. Changed plugs and it still does it. Plugs were black. Has oil injection and seems to be using oil, although not as much as if it were mixed in with the gas. Any help would be greatly appreciated. Thanks!
sloopy
Re: Nissan 70
something is wrong. way wrong, bring it to your deeler!
ivar
Re: Nissan 70
It can also be a fuel restriction. <br />Have you tried squeezing the primer bulb to see what happens?<br />With oil injecton , the engine will mix oil at approx. a 1:150 ratio when idling and 1:50 at wot.
jcadu837
Re: Nissan 70
The bulb is nice and tight seems to have plenty of fuel going to the engine. Also the vents are open on the tanks.
