Nissan 9.8 2-stroke telltale tube pulled off - where to reconnect?
fortunate2001
A little boy yanked on the telltale hose and handed it to me... a short (2") piece of hose maybe 1/8" diameter.
I went to put it back, and can't figure out where it should connect. On the bottom where I thought it should go (see picture), there is a small hole, but too small I think for this piece of tubing. Maybe there was a barb fitting or something else that is now missing? How to reconnect?
Maybe it's not a big deal, and I'm just making myself worried picturing salt water spraying around inside somewhere...
pvanv
Re: Nissan 9.8 2-stroke telltale tube pulled off - where to reconnect?
You may find a bit of corroded hose barb inside the end of the hose. If the new, non-hose telltale outlet doesn't cause water to spray where you have problems, don't worry about it.
fortunate2001
Thanks for the reply. There was no barb debris (at least by the time I got the hose...)
So, there is no matching tubing on the inside to which my short piece should connect? Just cooling water circulating on the inside? In that case, I may not need to worry as you said.
But, I will probably try to reattach the hose, if just to keep the salt water from dribbling all over. The motor is often used in short bursts as a tender, and not always rinsed off properly. I'll try the parts diagram again, see if I can locate that hose barb...
p.s. I noticed in a few of your previous posts that your business includes parts sales. It may be bad form to post links, but a hint (like the name) would be helpful... (Or a PM).
Tks.
