ronboonville
Thread starter- Joined
- Jun 6, 2012
- 287
After replacing my impeller it did not pump any water out of the telltale. after sleeping on it I thought it all was pretty easy. So I took it back apart and discovered the impeller keyway slot is only open on one end. if you do not have it the right way it will push the key out of the slot. live and learn, and don't be afraid to do-over till you get it right. maybe should post this under stupid human tricks.
