rogerwa
Thread starter- Joined
- Nov 29, 2000
- 2,339
Late last year when I pulled the pontoon out of hte water for winter layup, the engine was having a problem that I deferred looking at until now.. It would not idle. It would peter out and die at anything below 2000 RPM. Above 2000 it would run great.
I had pulled the carbs two years ago, but decided that is where I would start. I pulled them apart and they appeared very clean and I blew air through the passages. I would be very surpised if they were clogged. In fact, I could see daylight throught the idle circuit.
One anomaly I did find is that the float did not seem to be set correctly. The measurement from the manual says that it should be set at .76" +- .059". All three of mine were set closer to .625 (5/8"). At this measurement, it would put more fuel in the bowl that the specification would call for.. Could this be a cause of my issue?
If so, how can adjust these. I have adjusted floats before and this one doesn't seem to have anything to adjust. It has a plastic float and just a flimsey spring thing to attach to the needle.
Also, I pulled the fuel pump to examine whether it could be at fault. I did not find any tears in the membranes, althogh it definitely looked used. How taught should the membranes look?
I had another question about the fuel pump. My manual saya that the spring that is used on the engine side membrane is no longer needed. Does this mean that the new kits do not require it or should I pull it out??
I am looking at fuel as it doesn't look like compression issue (I believe I checked it last year and it was normal), and electrical works at high speed so I would think it is fine at low speeds..
Any help on diagnosing this would be great. I did not reassemble yet as I was seeking additional info..
