Hello all and let me take the time before hand to thank you for reading my post.
I was out fishing the other day, and after running about 15 miles and the motor running perfect I opened her up to WOT and trimmed up. After about 1 minute of WOT I heard the overheat alarm go off. I immediately backed off the throttle and let the motor Idle. I notice Water was coming out of the tell tale. After a few minutes I put the boat back in gear and take off, keeping my RPMS below 4000. I look back and notice that water is coming from the tell tale in bursts rather then a steady stream, and the alarm goes off again. Instantly I go back to idle, water is still pumping out of the tell tale, not in bursts, but not as powerful as usual. The Overheat alarm was on for less the 30 seconds total and I idled back home for another 5 miles and as long as I didn't go above 2000 RPM, everything was fine. When I hooked it up to the muffs/hose, the motor pee'd fine at all RPMS, but I suspect that is because the system was pressurized.
I pulled the lower unit yesterday and took a look at the impeller/water pump housing. It looks bumped and bruised, but still in a functional shape. I took some pictures but cant figure out how to attach them. Could some one help me with that?
Do you guys think I damaged my motor at all? Its a 2000 NS50D with 140 hours. Overheat alarm was on for less then 30 seconds total.
Also, do you think a new water pump/impeller could fix the problem?
Thanks
Thanks
