shotgunwilly
- Joined
- Aug 24, 2009
- 4
I have a Nissan NS90A outboard that I use probably atleast once every 2 weeks. Last time I took it to the lake I noticed water coming out of the cowling drain and when I removed the cowling water was spraying out of the outer Exhaust Cover Gasket. There is a place on it where it seems to have ?blown? out of the side. Water was still peeing pretty good even while some was spraying out of this hole. I have ordered a new gasket and plan on replacing it, but my question is do I need to replace the other gasket also? There are two, seperated by a plate. I?m wondering if the gaskets are crush fit and if I remove one, then will the other need to be replaced also? Or can I get by, by not removing the inner gasket and just replacing the outer? Also, is there anything I need to be careful about when replacing besides having clean flat surfaces and torqueing to the correct lbs? Could this have caused any damage to the motor?
