As more oil related posts begin to pop up again, I thought members might like to know that the National Marine Manufacturers Association (NMMA) has included detailed and somewhat technical explanations of the new FC-W oil certification program at their web site:<br /><br /> http://www.nmma.org/certification/local/downloads/documents/FCW_TestManualRevOct.pdf <br /><br /> http://www.nmma.org/certification/local/downloads/documents/FC-W_PAS-Rev_Oct.pdf <br /><br /><br />This information supports the fact that marine oils must meet different and more demanding performance criteria than automotive oils. Of interest is the salt fog test, rust test, and fuel dilution test. Some testing echoes the API, but other criteria for foaming, aeration, and high temperature shear viscosity, etc. have been stepped up a notch. <br /><br />It appears Southwest Research Institute and Perkin Elmer Automotive Research will be doing the testing and evaluation. An actual Yamaha 115 4-cycle outboard (6000 RPM) is used as the standardized test engine (the NMMA has verified that the FC-W certification applies to all marine 4 cycle engines, including inboards and stern drives). <br /><br />The performance of the oil will be determined, in part, by measuring actual wear of engine parts such as the cam, pistons, connecting rod, cylinders, main bearings, crankshaft, and so on. Southwest Research has provided TC-W3 oil testing for the NMMA in the past.<br /><br />The NMMA has made it clear that test results are owned by their Office of Test Data Administration (OTDA) and can not be divulged or discussed without the sponsor's expressed written permission.<br /><br />It appears the NMMA has made a great effort in making sure we are provided the best oils for marine use, and that we can buy those oils with confidence.
