Elmer Fudge
- Joined
- Aug 25, 2003
- 1,881
Okay i turned on the heat for the first time this season and what do you know? no heat,T/stat set to auto ,temp setting set to 75 degrees,system setting moved over to heat all i got was a loud click from the unit in the attic.So i'm thinking, well, just give it a minute and it'll kick on,...two minutes....three...four.. hey!! this ain't the norm,so i shut it down,switch from auto to fan and WOOOAAAHH!!! The whole house filled up with smoke.all the smoke alarms started blaring.SO! i opened all windows,doors turned on the celing fans,grabbed a couple of portable one's from the garage and promptly begin to air the place out.Brrrr!! After freezing of the you know what, for a while,i switch the system back to heat.Left it on fan and VOILA!!I started to get heat.But when i switch from fan back to auto..Nothing happens. some body explain to me what's going on here?
