no brake or turn signal
stylesabu
Re: no brake or turn signal
i have a 2005 dodge caravan,had same problem. running light no turn or stop at trailer van lights were fine. My convertor for the trailer had a bad ground. once i fix ground in the van for convertor problem solved.
johnson89
I have 2 grounds wires going to the conveter and still have no brake or blinkers.....I sent curt another e-mail about my problem I am sure I want get a repley till monday,,,,,,,,,,,,,,,,the first conveter I had work for a year but the new 1 they sent they sent me does not work. the trailer was set up this way I did not change any thing............
UncleWillie
It sound like the converter is just on the hairy edge and works intermittently.
The new one may be just a little closer to the edge than the older one.
Just for experimental purposes to see if we are looking at the real problem; Pull the bulbs or disconnect the Amber side lights and see if the issue goes away.
If it doesn't we can rule out the overloaded converter theory.
Another thought.....
You may have a bulb that is about to burn out and is pulling too much current and causing your symptoms.
An AMP Meter in the Green and Yellow leads could detect that.
An intermittent short in the trailer wiring would do the same thing.
johnson89
my friend brought over his truck and every thing worked fine all lights worked,brakes,blinkers...I checked his volts on the brake lights....11.3 volts...I have 11.3 volts also this was a few hours ago..........just went out and unpluged the amber lights,,,,left blinkers work,,,,right blinkers work....turn on flashers only the right side flashes........ the 2 tail lights on the back are brand new,even the wiring is brand new(new plugs)
MH Hawker
yea its on the truck, buy a new converter at advance auto.
UncleWillie
...just went out and unplugged the amber lights,,,,left blinkers work,,,,right blinkers work....turn on flashers only the right side flashes........ the 2 tail lights on the back are brand new,even the wiring is brand new(new plugs)
Left Turn Signal Works = Yellow Circuit INTO and OUT of Converter OK
Right Turn Signal Works = Green Circuit INTO and OUT of Converter OK
Brake Lights ??? = Red Circuit INTO the Converter ???
Emergency Flashers = Both Turn Signals at the Same time
Only Right Side Flashes = Green Circuit Good And Yellow Circuit Faulty. :confused:
Still looking like a converter issue.
Trouble shooting rule #2
If the symptoms make no sense at all and it appears to be magic; It is most likely a Ground Issue.
Triple check that White Ground Wire coming from the converter.
It should be touching clean bare metal under the lug, NO Paint.
Do Not trust the screw to carry the current.
The Curt Web site shows the #55382 Converter only has ONE White wire.
You have TWO???
roscoe
What an ordeal.
Really have to wonder why you have amber side lights hooked up to the brake light circuit?
All running lights should be hooked into the tail light circuit.
The only other suggestion, as it is the answer to ALL towing/trailer issues, is that you NEED a new Ford F350. I can't believe it hasn't been suggested yet.
johnson89
there is 1 white wire for the converter ground.I added another ground wire that is bolted to the suv,to make sure it was a very good ground,so ground is made in 2 diffrent spots,even made sure the paint was removed...just got up and rechecked everything,only running lights work....no brake or blinkers,even unpluged the 2 amber lights and still nothing...................
MH Hawker
:deadhorse: its on the truck replace the converter. Its a jeep their known for it.
saginawbayboater
Hey man sorry you are having such a time of it!!! This kind of stuff can test your sanity!!! You are doing a good job staying after it, most would have thrown in the towel!!!
One more thing to look at and maybe you already have, is the suv wiring harness just in front of the converter hook-up. I don't know if you originally installed the converter or a previous owner of the jeep, but some times people pierce the wires with a pointed test light to figure out which wire is which. If the converter is a plugin style they probably did not do this but it is still a good idea to get a visual on the wires for that issue. If pierced the wires will swell up and turn green and fail eventually. Also look for scotch locks that's also a NO-NO!! both of those issues can cause a lot of grief!!!
I can see having one bad converter and you changed it and you have the same result. I wouldn't think you would have two bad converters. But with Murphy's law it's not for 100%, but maybe 99.
Good luck!!
beardeddone
I still would have wired it up direct without the converter even if I had to add a couple of small lights on the back of the trailer for turn signals.
That is crazy and apparently bad converters or wiring harness for converter is wired wrong.
Maybe even switch bulbs on trailer to LED's to bring voltage/amp requirements down..
Wow
johnson89
yes its a plug in converter,I installed it last dec.2011 when I sold my truck and bought the suv....it has worked perfect for a year untill a few weeks ago.............
saginawbayboater
With the converter unpluged, and the jeep wiring put back to original factory setup, do the jeep lights operate correctly?
If they do, and we know the trailer is good, other than the forward facing amber brake lights, then it's pointing back at the converter?
UncleWillie
With the converter unplugged, and the jeep wiring put back to original factory setup, do the jeep lights operate correctly?
The Jeep's lights have never been a problem with the trailer attached or not.
The Trailer's lights are intermittent when attached to the jeep.
The trailers lights work when tested separate from the Jeep, but intermittently when attached.
The problem is in the connection, and the connection point is the converter.
This thread has taken on a life of it's own! :D
johnson89
yes the lights on the jeep are fine,never a problem....the trailer is a hit and miss,sometimes they(brake&blinkers) will work,sometimes only with the motor running,but the jeep lights have never fail to work,,,never got a reply from curt yet....you can unplug the trailer at anytime or plug it in and jeep lights never miss a beat,its only on the trailer side,,,,all wires on trailer are solder and heat shrink and new....all the lights are seal,you cannnot change bulbs,100% wterproof,I even checked with a light to make sure no water ....if I don't get a answer from them soon.I might try a MODULITE HD 119190 converter........
MH Hawker
I started just buying stuff for towing only from Reese. I used to have several trucks that were used and had a lot of issues till I swapped to their stuff and it stopped.
