No Charging or Tach - 1963 Merc 1000
bh357
I have a 1963 Merc 1000, and the motor is not charging the battery. The tach is also not working.
I checked the rectifier by disconnecting one of the yellow wires, and checking the continuity across the terminals (yellow to ground, yellow to red). I showed continuity in one direction, but not in the other. Checking red to yellow read opposite to checking ground to yellow.
I disconnected one yellow, and checked for continuity across the yellow wires: a few ohms (~10) resistance.
With the engine running, I measured about 17 VAC across the yellow wires at idle. This didn't change when I ran the engine to a high idle, or "goosed" the throttle.
I measured about 12 volts across the output of the rectifier at idle. This did not change when I ran the engine to a high idle, or "goosed" the throttle.
Does anyone have any ideas? Thanks in advance.
bh357
Re: No Charging or Tach - 1963 Merc 1000
Thanks phatmanmike. So, I'm guessing that the stator should be good?
What rectifier would be best for this motor, as the proper one is no longer available?
crazyinkc
I used the Radioshack rectifier on my 68 1000ss and it works great. My original rectifier checked good too but they were bad. $3.69 and a little rewiring and it was ready for the lake.
