no driving lights
LEKNIGHT
i have a 04 silverado. just bought a boat and the lights for everything works except driving lights. turn signals work. brake light works. im not sure if there is reverse lights but im not concerned with those for now. the previous owner swapped in LEDs if that matters
1730V
Re: no driving lights
I assume you mean LED's in the trailer?
If the trailer, did he replace the whole light assembly or plug in LED bulbs?
If he plugged in LED bulbs, he may have the wrong type. There are 1156's and 1157's. You need 1157's to get all three functions.
Ayuh,........
About all you can do is,...
Grab a Test Light,+ Start at the Truck Connector,+ Go til you either Find, or Loose the Power...........
Sea Ray
You probably have seperate fuses for each circuit for the trailer. Look under the hood for the trailer running light fuse.
My suburban had the same problem.
mikey.himself
May have a short in your running lights , that has blown your fuse on the vehicle. . .
moterboat
driving lights??? are you talking about the TAIL lights on the trailer? or the truck? or the headlights on the truck?
