LakeWatereeSCBoater
Thread starter- Joined
- Jan 16, 2017
- 7
I have searched and tried everything I can that I have seen in these forums and I'm stumped.
I have a 83 80hp Mercury blue line around cover.
I have no fire on any of the four plugs but the motor is turning over fine when turn key, and here is what I have checked so far.
Removed both yellow wires from stator even though I believe those are charging wires. No fire
Removed both black/yellow wires. No fire
Ran wire directly from battery to fuse box. No fire
Tested power from battery to starter and Selenoid. Tested power fine.
Tested the rectifier (which has one red and (two yellow from stator to it)). Have power on red and the middle yellow no power to second yellow
Where do I go next or is the rectifier or stator bad?
