I have a 67 fisherman cannot seem to make it fire. Any suggestion
J jason34 Cadet Joined Jul 17, 2013 Messages 6 Jul 17, 2013 #1 I have a 67 fisherman cannot seem to make it fire. Any suggestion
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jul 17, 2013 #2 Re: No fire I would start by pulling the flywheel and checking the points, make sure the coils are not showing any cracks.
coolbri70 Lieutenant Commander Joined Oct 6, 2011 Messages 1,554 Jul 17, 2013 #3 Re: No fire clean the points:noidea: I type slow, what he said /\ Last edited: Jul 17, 2013
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Jul 17, 2013 #4 Re: No fire Daviet, you're back. Where were you ???????
J jason34 Cadet Joined Jul 17, 2013 Messages 6 Jul 17, 2013 #5 Re: No fire jason34 said: I have a 67 fisherman cannot seem to make it fire. Any suggestion Click to expand... I have cleaned the points the condencers coils seem to fine
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jul 17, 2013 #6 Re: No fire If the points are clean and adjusted properly, and the condensers are not shorted, I would think you have a coil problem.
J jason34 Cadet Joined Jul 17, 2013 Messages 6 Jul 17, 2013 #7 Re: No fire I took the coil loose and the plug wire came right out of it. I do not think this is normal.
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Jul 17, 2013 #8 Re: No fire The coils wires are just pushed or screwed into the coils. Does the wire look rusted or corroded where it goes into the coil? You can cut a little off of the wire and reseat it into the coil tower.
J jason34 Cadet Joined Jul 17, 2013 Messages 6 Jul 17, 2013 #9 Re: No fire yeah it was corroded i will try that tomorrow thanks
J jason34 Cadet Joined Jul 17, 2013 Messages 6 Jul 17, 2013 #10 Re: No fire every thing under the fly wheel feels like it has oil on. Would spraying some carb cleaner on there hurt anything.
F fromcarsToboats Seaman Apprentice Joined Jul 10, 2013 Messages 46 Jul 17, 2013 #11 Re: No fire good right ahead just use some air and blow it off
