No forward
edmurphy
I have a 69 electric shift Evinrude, it goes in reverse but kicks out of forward when you give it throttle, I took the lower end apart but didn't see any metel in case, does anyone know what the resistance of the shift coils are.
LEFT THE LAKE BACKWARDS
ED:confused:
edmurphy1954@yahoo.com
Dhadley
Re: No forward
Keep in mind it's not an electric shift but rather a hydro-electric. If you apply electric shift logic you'll get very confused.
I don't have the solenoid values but I'm sure Joe Reeves will be along shortly and I'd bet he does.
edmurphy
Re: No forward
Where did hydro come from? You put 12v to coil, it makes a mag field-pulls spring to engage gear.
Dhadley
Re: No forward
My mistake - I got 69 55hp from somewhere.....Since we don't know what size motor you're working on it could be an electric shift.
F_R
Honorary Supreme Mariner
Re: No forward
The coils should be approx 8 ohms. They draw 1.5 to 1.9 amps.
So, didn't you check out the electrical system before tearing the lower unit apart? 90% of the shifting problems are in the wiring or shift switch. ESPECIALLY the push button shift switch. You need to check the voltages at the blue and green wires (wires not disconnected).
