Not sure of year, Mercruiser 4.3 alpha one, engine number OD707859, I m new to the forum and to boats, never had one.
This boat is abandoned on my property, 1992 180 SE Glasstream in poor condition, I m trying to see if it will run. I put a battery in it and it will crank over but not start, I removed the fuel line to the carb, put it in a plastic jug and cranked the motor it is not getting any fuel into the carb. A boat mechanic told me that there is a antisiphon valve in the fuel tank that could be the problem. The tank is about 3/4 full of gas. I removed the fuel line from the tank to the mechanical fuel pump, there was no gas in the line. I m trying to decide if I want to spend the money to put a lien on it, to get title, so my objective is to see if the motor will run without spend a bundle of money.
I have used a test light on the ignition system and found a bad connection.
any ideas?
any ideas?
