No idle!
strtbobber
I have a 1977 55hp Evinrude (new to me) which will not stay idling. It's very hard to get to start, and when it does, I have to rev it quite high to keep it running. Then once the rpm come down low enough, I have to put it in gear and nail the throttle, other wise it'll die. Sometimes it takes quite a while for the rpm to come down. At WOT it runs great! I'm thinking of rebuilding the carbs......how likely is it to fix my idle problem? I have already rebuilt the fuel pump. Thanks!
strtbobber
Re: No idle!
Thanks fireman. I rebuilt them today and ran it up on the muff. All seems well. At least it idles. Gonna take it to the river tonight to do a on trailer power test.
fireman57
Re: No idle!
basically you want to make sure that the carb butterflies open equally at the same time. The procedure does it for you.
strtbobber
Re: No idle!
Yeah, I had already done that. I bought a timing light now. I read in my manual about adjusting the throttle linkage to 2-4 degrees btdc. Got that done and it idles better now. So, once again, I'll take it to the river tonight to power test it on the trailer.
hondarider188
Re: No idle!
i have the same problem with my 1984 evinrude 140hp, bu it has gotton better at i run it more but is there some typr of fuel additive that i could run through it to clean out the carbs and engine.
fireman57
Re: No idle!
honda is talking about seafoam. It is a great product and I make sure I have a few capfuls in each tank of fuel.
