redneckrob01
Thread starter- Joined
- Aug 26, 2012
- 3
bought a 88 bayliner with a 50 force. at first it would crank fine when cold but after you ran for a while you could not start with key. put a rope on it , one pull and it would fire right up. now it will not even start when cold. you can jump the solenoid and start it when the key is on. tested trip wire on solenoid and it is getting juice when key is in start. figured solenoid was bad and of course it is obsolete so i got one at a local mercury dealer that is similar. put it on and same thing. then every once in a while it will crank with the key (which it did while i was checking wires with a test light). got power from battery to solenoid. power from trigger wire. but no power through solenoid. i have checked all that i know to check. ready to use it for an anchor if i cant get this figured out!!!
