No model number need help
dropbear68
Im vexed big time so before I drop this motor in the trailer and go dump it, my plate on my Johnson V4 has a tag but the model numbers worn off with only the S on the end remaining, now ordinarily Id look on the timing sticker it would at least give me the horsepower which is what I want, I was told its a 120 but they didnt cone out till 1985, shes very pre 85 is has the external trim motor the big tall one, the cover is not its original , can the serial number give up anything 613952, if its an 85 its definately off to the tip.
dropbear68
Ok jst got the low down from the boat mechanic who i got it off apparently its a 135 power head with 120 carbs and reeds, now Im happy.
jimmbo
That mechanic/seller is full of something brown. The carbs/reeds from a 120 will not fit on a 135, or any non looper V4. A few pictures may or may not help in getting a rough idea of the year.
Edit: Based on the ? tall external trim pump? that would place it 73 - 77
Honorary Supreme Mariner
External trim motor puts it in the 73 to 77 range.----No 120 model in those years.------Pictures and more pictures need to be posted !
dropbear68
No Title
Its only got tilt no trim, heres some pics its got an evinrude top cover i dont like the johnno tops
dropbear68
Mechanic is adamant its a 135, a look at the power head tells me its been apart, the timing piece cast into the manifold is broken off so manifold needs changing anyway
dropbear68
Bottom thermostats mean cross flow not loopy that much i know lol i know it also has the dual cables for control box not the selectric bullshit, i just hate 85 s so if its bigger then 85 im happy if its an 85 its off to the tip ill stick with my 115 chrysler and its leaky shock absorber which is the only reason the omc is going on the chrysler wont trim below pin setting number 2 for some unknown reason
Faztbullet
1)First find you a mechanic that knows motors 2) Most likely a 1976-77 85hp as 135hp has exhaust hump
Agreed-----The 135 hp has the bubble exhaust.-----Yours does not !!------And find another mechanic I say.
jimmbo
Ok if its 85 its of to the dump
It might be a 115.
Why do you have a hatred of the 85? With 92.6 cu in it was a very low stressed torquey engine
And as suggested, find a better outboard mechanic
V153
I'd make it run and sell it for a few hunnert bucks before hauling it to the dump?
V153
Fwiw I have a complete 'boomerang' ignition system for those motors. New coils/plug wires and CDI powerpack. 'Case anybody needs one.
