SgtMaj
- Joined
- Nov 19, 2007
- 1,997
Re: No more Lake Mead?
Actually they would have to be less than 1km per satelite. You're not trying to totally block out the sun over 1% of the earth's surface, you're only trying to block out 1% of the sun over the entire earth's surface. Now you're probably scratching your head about how to do this, but it's really quite simple, you just position them where the solar observation satelites are, that is at the point between the sun and the earth where the gravitational pull between the two cancels each other out. That is sufficently far enough away from the earth that you will be blocking a percentage of the suns energy across the entire earth. 1% is a huge amount by the way, it only needs to be something like .0001% to be effective enough to reverse the effects over a period of time.
Considering that the profile footprint of the earth is 15,705,369 square miles, 1% would be 157,053 square miles, or 1.005135e+008 acres. The satelite deflectors would have to be well over 100 million acres. Now there's a well thought-out plan.
