No muff holes on chrysler 1970 55hp
brnschoneck
So this may sound stupid however my first chrysler motor ive owned ..There is no place for muffs i beleive the water inlet hole is in the front triangle shaped pretty big hole,I think this is the hole that sucks water up correct ?? ??? Is this,kinda on top of propellar under cavitation plate, so and can I just stick the hose in there rather than filling up a big old garbage can to use a a test tank ???
wickware
Re: No muff holes on chrysler 1970 55hp
Attached is where muffs would fit over the screened intakes. The Muffs are not as good in getting cooling water IMO. I use a 55 Gal Barrel with a drain plug that a water hose will fit onto to empty (onto the yard away from working area). This has been a once a year start-up event that has worked well.
  • Copy of 70 Chrysler, 35 HP, Marked Vent & Oil Drains & Non Marked Screw.jpg
brnschoneck
I dont beleive mine has them holes i thought it would be the triangler thingy in front of prop there that angles down..ill look again but i dont beleive it has them ??? same motor though ??? how u like it ? urs looks preetyyy clean too..my cover says alternator on it may be a little different style not sure ill try n get some pics up today ???
jerryjerry05
Some older ones don't have the holes like Wick showed.
Your right about the pickup.
Put it deep in a bucket.
Needs to be 2-4 inches OVER the top of the water pump.
See the oil fill screw in the pic. The pumps above that.So put it in DEEP!!!!
wickware
1. I?ll be interested in seeing your Pics to add to my collection of Chrysler?s 35-55 hp pics and info.
2. My 1970 Chrysler is a 35 hp with a 55 hp cover/hood. I Have Loved It Since 1984!!!!
3. It does not have an alternator but electric starts instantly with starter or rope.
4. More pics of my 35 hp that has been all I need. It can smell a fish a mile away.
5. I ?had? (LOL) automotive and small engine training and experience 1960s-90s that helped when needed.
brnschoneck
1970 55hp chrysler 006.jpg1970 55hp chrysler 001.jpg1970 55hp chrysler 002.jpg1970 55hp chrysler 003.jpg1970 55hp chrysler 004.jpg
Here are some pics for you enjoy ???
brnschoneck
brnschoneck
1. I’ll be interested in seeing your Pics to add to my collection of Chrysler’s 35-55 hp pics and info.
5. I “had” (LOL) automotive and small engine training and experience 1960s-90s that helped when needed.
has it been a good motor to ya ???as u can see mine has been takn care of well and compression on it is perfect i plan on keepn it a while i hope it runs good for a loooooong time ....
Nordin
As jerryjerry says, older 35-55Hp Chrysler did not have any holes for pickup.
You have to put in a deep bucket. Waterline above the waterpumphousing (about 4-5 inch above the caviatorplate).
wickware
There is no end to the learning about the old Chryslers 35-55 hps. Now I wonder if the PO of my 1970 35hp had a later lower unit installed to have the screened cooling water pickups (since no white paint was on that section). That was the best purchase, I feel PO wanted the motor and boat treated as his family had from new. He gave me a course on do and don?ts (which I needed as a 1st owner above a 5 hp John Boat owner) on about a half hr - hr ride on the water. Running it bone dry, (1984-85) before leaving the lake every trip was wasting too much gas if I was going out the next week. That was about all I adjuster from the PO?s care.
brnschoneck
okey dokey that stinks lol !!! more work lol....I fired her up yesterday ...
brnschoneck
so i fired her up yesterday she purred two concerns ?? 1. no stream outta tell tale only strong spray but it sprayed out preetyy far is this acceptable ?? I know ill have to do a water pump soon just dnt know if ill get to it before sunday when i wanna go out .
2. rough idle i adjusted carb , and idle screw out a little couldnt get it to low 850-900 range with out it dying coughing any suggestions ?? the po did have carb rebuilt in may and stored dry since so its been sitting a couple mnths anyhow .. Im hoping after i run it a bit itll calm down ??? also does anyone have the part number for this waterpump ,and where yall get ur parts ??
jerryjerry05
First off it's NOT an idle screw.
It's a fuel/air mix screw.
Turn it in till it just bottoms out GENTLY!!!
Then out 1 turn for inital adjustment.
Then set idle at about 800 in gear.
Then slowly: 1/8th of a turn in.Wait 10 seconds and then another 1/8th. Do this until it bucks or kicks then out 1/2 turn.
Gott wait 10 seconds for the motor to use the gas at the old setting.
The idle is adjusted with the towershaft.It has a screw with a locking nut that rides up against the block.
This site sells parts.If they don't have what you need??
Try Valley Sales in Prudenville,Mi. Or Franz marine.
Boats . net is a JOKE worst place to buy parts on the net. That used to be the only place I bought, then they got too big and customer service went to He%^
wickware
I used the advanced search at the top and entered wickware (as user name) water pump (as the key word) and found my water pump replacement info + more on my 1970 35hp Chrysler at the address below. I ordered my impeller from here at the best price due to price matching and US Postal lowest shipping rate.
http://forums.iboats.com/force-chry...etting-good-stream-70-35hp-chrysl-362497.html
