Efini Motorsport
Thread starter- Joined
- Feb 21, 2018
- 108
I'm picking up a new boat tomorrow. Found a 97 Monterey 210 cuddy with a 5.7gl volvo for a price I couldn't pass up. It's in good shape overall but the engine has no oil pressure ( the reason it is so cheap). The previous owner said he was out one day and everything was fine. He went to start the boat and it would run for a second then die. Tried a few times before getting towed in. When he brought it to his mechanic (a friend/ neighbor of his who is a marine mechanic) the mechanic did whatever diag and said he had zero oil pressure when a mechanical gauge was hooked up. I'm trying to figure out if there is an oil pressure sensor that could stop the engine a few seconds after it starts or if I'm going to have to start by replacing the oil pump. The engine has an aftermarket holley performance carb but I'm not sure if there is an electric or mechanical fuel pump. If I have to do the oil pump I'll just pull the engine and tear it down for a rebuild. If it's something external though it would be even better.
