capsnumber1
Thread starter- Joined
- Mar 25, 2006
- 45
Hi all, I just purchased a new fuel sending unit for my 89 Evinrude 120 HP. Whenever I turned the key on, without the engine even having to be started the alarm would continually sound. I finally isolated the problem down to the oil tank sensor. I bought a new tank sensor and installed and no more alarm. However, when I start the engine on a garden hose I can't see oil coming out, just clear water. After the engine is started for about 30 seconds the no oil alarm starts to go off. I disconnected the oil line at the midway point between the engine and the tank (which is where I connected the new line) and there was oil in the line. The oil ball is hard. This would make me think that the VRO pump went bad, however last fall when I started the engine with the alarm sounding (on the old sensor) there was oil in the water, which meant the pump was functioning. What could I have done wrong in the new sensor hookup to cause the engine not to get oil? It seems like all you should have to do is connect and tighten the hoses and plug in the wires, which is what I did. Could the pump have broken over the winter? What kind of tests can I run to see what exactly is wrong? Thanks!
