Myfirstboat86
Thread starter- Joined
- May 31, 2012
- 13
1973 mercury 50hp model 500 inline 4cylinder. Dual carb. Took boat to a shop. Had the carbs done, upper crank seal, fuel lines all the way back, water impeller and timing adjusted. Cost $680. Get the boat back and take it out for first time and it starts right up, idles great, at wide open throttle it only makes 4000rpm and only goes 9.5mph. Took it back to mechanic. He says that no one is home in cylinder 1. At wide open throttle I can pull the plug wire off of cylinder 1 and the motor doesn't skip a beat. Sounds the same and continues to run with no change. I've tested spark and it's getting good spark. New plugs. Compression reading is 115psi. Mechanic says he thinks it has a scorn piston or a broken piston skirt. Is this a possibility? Like I said it starts right up idles and jumps right up to 4000rpm and 9.5mph. But that's all she's got. I've got a lot of time and money now invested in this engine and I don't know what else to do here. Any input or diagnosis would be greatly appreciated! Thank you!
