No opinions? C'mon people!
acad
Has anyone ever seen/tried/used the 'Gator' or 'Gorilla' truck bed paint on your 'toon deck? My son, who used it on his aluminum bassboat decks swears it will work great and outlive us both. I'm tempted, but hope for other learned opinions. Please advise...
EGlideRider
Re: No opinions? C'mon people!
OK. You asked. I think it looks awful 'redneckish' and would never want it on my boat. Even with the white, it will never be as comfortable as marine carpet.
acad
Carpet is impractical for me. I live on a very small lake (pond - 20 acres) and boat is on the water, in the sun, ALL the time. It's been at my dock for seven years. Short of bribing a neighbor and offering to re-sod his backyard, it's not coming out of the lake. Redneckish isn't an issue with me. I'm 61 years old, and I probably won't be able to replace the deck again. I need to put down a deck that will last a LONG time. Carpet, in my situation, looks horrible in 2-3 years. Heck, I'd prefer carpet, too, but between sun and mildew, I know better. I'm open for any and all suggestions for an alternative.
lmuss53
I've seen it in aluminum boats and in pics in the Starcraft restorations on iBoats and I think it looks fine on those. I've seen vinyl decks on 'toons and I think they look fine. It would be a lot of deck to have in the liner material, but I think it would look OK. I really hope you do it so the rest of us who've been thinking about it can see how it works for you. Go for it, and post up some pics.
asm_
I just can't help it. but I actually think carpet on boat is 'redneckish'...
Never did understand what was the very first person thinking when he decided to put carpet on a boat. I can only imagine he probably has carpet in his shower and bath tub... :p
I know I'm the minority here, but I prefer any thing other then carpet.
Bob_VT
Take a look at Durabak coating but.....whatever you decide to use keep this in mind..... it will hinder repairs and it costs a ton of money!
Consider vinyl too ;)
jusfloatin
I also have seen and talked to the owners of couple of boats with the Rhino liner and both have nothing but good things to say about the liner.
After a day of fishing they just hose the inside of the boat out.
I wonder how it would hold onto wood.
Being the financially challenged person I am, I have been considering the idea of just painting the sheets of plywood and throw sand on the top side to keep it from being to slippery.
I am not just talking about a coat or 2 but almost encapsulate the wood with paint.
I am sure it would require a new coat on the top side every couple of years but I doubt it it would take to long to do that with one person on a brush and one with a roller.
Probably about a 6 pack time line.
Silvertip
White or black, bed liner material will be hot -- just like vinyl decking (assuming you do go barefoot now and then). Then there is the slippery when wet situation. Unless you remove the entire deck, coat the underside as well, the deck will eventually rot away leaving you with a very useless expenditure on the surface.
EricStarr
I have to disagree with it being hot i have rhino liner in my aluminum flat bottom it is not near as hot as it was before i did it and i put down a beige color i have also thought about doing my pontoon boat i also think carpet on a boat is the dumbest thing i have ever heard of just like said above like putting carpet in a shower.LOL
EGlideRider
Eric, you didn't mention what flooring you had before the Rhino. If it was bare aluminum, anything would have cooled the deck.
EricStarr
It had carpet in it before i tore all of it out after about a year and did the rhino most of the boats like the one i have now come with the spray on bedliner.
tashasdaddy
light colored bed liner, you choice. carpet is as nasty as the little rug, the wife puts around the toilet, and we pee on at night, and walk on bare foot.
Mel Taylor
I did industrial painting for almost 40 years and used sand and industrial enamel to produce a durable, long lasting, non-skid surface on a lot of concrete, metal and wood floors. It worked like a charm and I can't see why it wouldn't work on a boat deck as well.
Here's the procedure I always used:
Roll or brush on a heavy coat of oil based alkyd enamel. This should be a good quality paint. Preferably one designed for industrial applications or for use on floors.
While the enamel is still wet, broadcast a layer of fairly coarse sandblasting sand (the kind used for blasting structural steel on bridges and buildings) on top of the paint. Just toss it on there by the handsfull Or, better yet, if you can find it in your area, use white silica sand, . Again, it should be fairly coarse sand.
When the paint is thoroughly dry, remove all the loose, excess, sand and apply another coat of the same paint.
For greater durability repeat the process.
Note: the paint I am talking about here is regular old slow drying enamel, the kind that uses ordinary mineral spirits for thinner and clean up. You need for the paint to be good and wet when you broadcast the sand onto it.
BTW, I've never had any luck trying to mix sand with paint and apply it that way. The couple of times I tried that, I ended up with a first class mess. Had to scrape it off and start over.
Boss Hawg
So whats on your pontoon deck now :confused:
I'm sure your right & the other 79,976,932 of us are just stoopid rednecks :rolleyes:
mla2ofus
I think the bedliner would tend to make the deck hold moisture that gets splashed on it from underneath and promote rotting faster.
JMHO,
Mike
And yeah, I'm one those 79 odd million also:D:D:D
