no power at wot
copmeemee
1981 johnson 50 hp model j50belcic...will only run at wot but has no power and when you try to bring it out of start it will die...got oil coming out of the prop. have changed the lower unit oil, the old oil looked ok..motor doesn't seem to be running hot
Benny1963
Re: no power at wot
check your compression, claen your carbs 'and do spark test .
repost from there good luck bennyb
