When I turn my ignition key to ON position I have no power to my dash gauges. On my ignition switch I have 3 wires. One is power one is for my dash instrument panel an the other goes to my starter. When this happens I still have power to everything else. Bilge pump, blower motor, lights, etc. so it's not a ground problem. I don't think. I thought I was blowing fuses bc I could replace the fuse going to the power wire an it would turn over. I checked what I thought were tge bad fuses last night ( a continuity test) an they were still good. Also this is only sometimes. Took the boat out on sat and ran perfect. Sunday no power. Got it back home and replaced what I thought was a bad fuse an it started right up on hosepipe. I'm confused. Help!!!! The motor is 1992 omc 5.0 with cobra out drive if that matters. Thanks for all your help.
