Re: No power to coil packs
Simply that is because the ignition system does not use 12 volts from the battery to produce the spark !-----Spark is generated by the electronics and the magneto under the flywheel when it is spinning at the correct speed.-What issues are you having and you might want to invest in a manual to help understand how this works and how to trouble shoot.
