No power to coil packs
rokhd
I have a 50hp Mercury serial # 6368228 and it isn't getting power to the coil packs or switch box. Any suggestions on where to start.
Re: No power to coil packs
Are you looking for 12 volts anywhere on these components when key is turned on ???
rokhd
No power anywhere with the key on except the starter solenoid.
Simply that is because the ignition system does not use 12 volts from the battery to produce the spark !-----Spark is generated by the electronics and the magneto under the flywheel when it is spinning at the correct speed.-What issues are you having and you might want to invest in a manual to help understand how this works and how to trouble shoot.
sam am I
Trick question or speedy recovery? :juggle: Interesting evolution thou.....I did look for that SN earlier, I struck out.
rokhd
I was thinking the coils had power on them even if it wasn't running.
