cddetelich
- Joined
- Oct 7, 2004
- 99
After sitting for an extended time (a week or more) my engine (1991 175 Johnson VRO) needs several attempts before it will start. If it does not start after 3-4 attempts, the next time I turn the key to start the system goes dead electrically- no starter spinning and all of the gauges on the dash go dead.
The first time this happened, I disconnected all of the accessory wires to the battery and just reattached the two cables, and the motor started. Then I reconnected the "little" wires, (bilge pump and some others) and everything seemed fine. Went out fishing several times, no problems, everything worked.
So, haven't been to boat in over a week, so I decide to go today to start motor for a while. 4 attempts to start, and then dash goes dead and no starter cranking whenever I turn key to start position. If I return key to off gauges work again, but as soon as I try to crank motor the gauges go dead and no starter cranking. Battery and cables are new this year.
Any ideas?
Any ideas?
