GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
I have 1971 glastron with 270 outdrive and the prop shaft is currently removed and i read in the manual that the oil pump is located on this shaft. Is it ok to run my motor on muffs while this prop shaft is removed?
Without the propshaft there is no oil in the drive, upper or lower. If you run the engine, you WILL destroy the upper bearings and gears....... You don't even want to know what that will cost.
