allenprimo913
- Joined
- Dec 27, 2008
- 63
Re: no response to my last 3 post
i rebuild the carbs and put new kits in there but i believe its probably the synchronizing parts that i can not maintain and adjust right.
it does not bog down when in gears, it bogs down when i accelerate it and it idles but doesnt response right?
i read some here that it could be my idle mixture screw adjustment, i maybe running too rich, i didnt know that this motor are so sensitive in turning the idle mixture. i usually turn it all the way in then turn out 1 1/2 then 1/2 turn in. i havent tried just turning bit by bit.
i am suspecting it could be the breaker points too or condenser for they havent been replaced since day one.
you are right about the rectifier, but could it be affecting the spark on the plugs when its at high RPM?
and i was thinking again if my points are bad, how come it starts everytime? and idles smooth and very stable. only when i accelerate to high rpm that it hesitate and when in gear. it doesnt die when i shift to gears.
and if in case the rectifier , i want to know if i can use those black square type so i can order here on iboats.
tnks again
tnks again
