Re: no reverice
if you have multimeter, you can do a ohm's check at the wires from the top. just measure across both. you should get about 15 - 16 ohms. each coils has about 7 - 8 ohms resistance across them. If you measure open circuit, big problem. If your reading is way above 16 ohms, you may have a bad conection or a coil about to die. if you get a small reading, then something is shorting out. (ps, to do the search, use the red SEARCH link at the top of the page, then type in selectric shift in the topic feild, and make sure that jonston/evinrude is selected in the forum to search field.)<br /><br /><br />Good luck
