turbocorrado
Thread starter- Joined
- Aug 14, 2013
- 251
just did outdrive reseal, bellows, and shift cable
not sure if this is an issue with my outdrive or what, with the outdrive off the boat, i can shift through forward and reverse by turning the shifter by hand and seeing the prop shaft change direction. bolted it onto the boat tonight and i have about 1/3 the movement out of the shift cable that i need to complete full shifting
i know with my outdrive sometimes when its off i cant get it into gear untill i turn the motor a little, wondering if this is the same kinda deal
