I have a 1986 Mariner 115 HP 6 cyl outboard. It has been called the the 3 on 3. I currently have no spark. I have checked all connections at the coils, switch box, including stator and trigger switch. Also checked the mercury tilt switch, fuses and of course battery. Got plenty of power, no spark. I think I could muddle through a volt ohm test but I do not no what I should be looking for in the way of ohm readings if any. All ready tried once for instance I tested out the trigger and got an ohm reading of 348? I was set x2000. all other settings showed nothing. I may be missing something entirely (is thier a heat sensor?) I was giving it the entiall beginning seasopn fire up in the drive way and was kicking over to begin with but suddenly went away? Pulled a plug got gas no spark. I have an electrical schematic and should be able to test. Just need advice on how to proceed.
