sad boater
- Joined
- Mar 23, 2026
- 40
Yes I have spark out of the coil, it's hard to see because of the sun but it is definitely there.Do you have spark out of the coil?
Yes I made sure it was lined up when I reassembled it. I was thinking the same thing but I'll find out in a little while when I pull it apart again. That's a shame but I can understand why lol. It fired right up after the amplifier was installed, do you think that being an aged part it could have spun off the notch? Not sure if it's original or not. It looked good so I reused it. It and the points are all that I didn't replace. Everything from the battery to the plugs.Did you line up the key on the rotor with notch in the crank?-----It sounds like you need another rotor.------Sent a couple of these motors to scrap a week ago.
Did you keep any of the rotos?? LolDid you line up the key on the rotor with notch in the crank?-----It sounds like you need another rotor.------Sent a couple of these motors to scrap a week ago.
fwiw from an intelligent source... things to reverify ....
If it fired briefly right after the new amplifier was installed, then died and now won’t restart, the most likely causes are:
Most likely causes
1. Loose / bad electrical connection (very common)
After changing the amplifier:
Check:
- a wire may be loose
- bad ground
- corroded connector disturbed
A weak battery or poor cable can let it cough once, then fail because ignition needs adequate cranking voltage / speed.
- battery terminals (clean/tight)
- engine ground strap
- amplifier mounting screws / ground
- coil wires
- kill switch wire
2. Kill / stop circuit grounding ignition
Sometimes:
can short ignition to ground.
- key switch
- kill lanyard
- chafed wire
Quick test:
If spark returns:
- disconnect the black/yellow stop wire (or kill wire) from the amplifier / ignition module
- crank again
- kill circuit is the problem.
3. No spark at plugs
Before chasing fuel:
Do a spark test
Look for:
- remove both plugs
- reconnect plug wires
- ground plug bodies to block
- crank
Weak / none:
- strong blue snap
These systems need decent cranking speed to produce spark. Remove plugs during testing so the starter spins faster.
- amplifier wiring
- bad coil
- rotor / cap issue
- points / trigger problem
4. Rotor not seated / cap issue
Since you were in ignition:
Engine can fire once, then stop if spark leaks.
- rotor may not be fully pushed on
- cap may be cracked / damp / carbon tracked
- center carbon button missing
5. Fuel issue (less likely if it fired right after repair)
Check:
If it fires on a tiny shot of premix into carb throat:
- primer bulb firm?
- fuel reaching carb?
- choke working?
- fuel delivery problem.
Best next step (in order)
- Charge battery fully
- Check all grounds and amplifier connections
- Test spark on both cylinders
- Temporarily isolate kill wire
- Inspect cap / rotor again
My email is allmostsuperman05@yagoo.com can you contact me through email pleaseI have some rotors stashed away.
Using a timing light during cranking I only have signal at cylinder 1fwiw from an intelligent source... things to reverify ....
Most likely causes
Check:
- bad ground
- coil wires
- kill switch wire
Sometimes:
- key switch
- kill lanyard
- chafed wire
Quick test:
If spark returns:
- crank again
Do a spark test
Look for:
- remove both plugs
- crank
Weak / none:
- strong blue snap
- amplifier wiring
- bad coil
- rotor / cap issue
Check:
- primer bulb firm?
- choke working?
After dark have someone crank the engine over while you look under the flywheel and see if the spark is shorting thru the plug wire boots.Using a timing light during cranking I only have signal at cylinder 1
I did that last night I did not see spark escaping from anywhere. What I have found is a slight wiggle on my rotor when fully seated, this can throw off the ignition timing, when I inspected the copper ring in the distributor I have noticed arc marks prior to the brass area that it should be hitting. This tell me it is not firing the spark at the right time. The #1 had spark but it is much weaker than the spark from the coil wire to the distributor. I am currently debating on replacing the distributor, rotor and wave spring to insure all parts are new. That only leaves the key switch itself or the harness but I have verified all needed signals to produce sparkAfter dark have someone crank the engine over while you look under the flywheel and see if the spark is shorting thru the plug wire boots.
Spark from coil wire jumps 1/2 nice blue spark. Extremely weak spark at plug #1 had to 1/8 from ground to get a spark. I have nothing at #2 or #3 signal tested with timing light. I'm leaning towards cap and rotor it's all it can be. I'll have to wait to buy the part they are another $400 for the cap and rotor.You really need to find out if your spark is strong enough to start with! purchase an adjustable gap spark tester and set it to 3/8in. then check spark at the coil wire. If spark wont jump 3/8 at the coil, diagnose that first! If it does jump 3/8 at coil wire, then proceed to check at each spark plug terminal. If you have spark to weak to jump 3/8in at the spark plug wires, then MAYBE you have problem with cap and rotor.
No play in crank the wiggle is at the notched area it can turn side to side in the notch it sits in, my understanding is that it has zero play tolerance. Despite play from side to side can cause it to throw the spark at the incorrect time causing the plug not to fire correctly or not at all according to what I understand.You stated you had a slight wiggle on the rotor! Does the crankshaft have side play? If you have side play(excess play)that will affect the point gap!
I verified the gap on my points on all lobes twice just to be sure that nothing exceeded the recommended adjustment. I'm thinking I got a bad distributor because it doesn't seem to be taking the spark and putting it where it was supposed to be so I'm going to wait and save my money and order a new cap and rotorWave washer secures the rotor !----Rotor does not control timing.----Opening of breaker points controls timing
