gerald trentham
Thread starter- Joined
- Sep 27, 2006
- 22
Took flywheel off to clean it and components underneath it. Put it back on and now have no spark. Any suggestions why?
Herra said:Yes, I have ineed;
You have not read followed and unerstood the troubleshooting test that has been sent to you by ML.
By the way, stop fuzzing around go and buy a new used coil from iboats member PurkaAamo (cheap)
TOHATSU said:Gerald,
Did the flywheel key make it back into place when you placed the flywheel back onto the engine?
There isn't any reason that that you would lose spark from taking the flywheel off and putting it back on again. It could just be fate, but here's the quick list of possibilites:
Blown fuse
Kill switch lanyard
Defective kill switch
Defective ignition switch
Loose or bad wire
Bad CD
Bad trigger(pulser) coil
Bad exicter coil
Bad ignition coil
If you managed to drop the flywheel there is a 1 out of 1000 chance you could have damaged the magnetic field...I've seen it twice in 40 years. But it's more likely that you blew the fuse or CD.
You need a manual for the test procedures for the ignition system. You can pick up an aftermarket one here on iboats or a factory original from any Nissan or Tohatsu dealer.
Avoid posting to old Inactive topics and avoid duplicate posts.I pulled top spark plug wire off while motor was running great 90hp nissan outboard engine shut down immediately now wont start no spark on all 3 cylinders tilt and trim works and electric choke works..no spark on all 3 cylinders...need help
I was starting up my 90hp nissan for the first time in years it was running great and i called my self checking cylinders and pull the spark plug wire while it was running..engine shut down immediately and would not start,check for spark nothing on all 3cylinders checked fuse it was good tilt and trim and electric choke working need help thanx
