Raystownboater
Thread starter- Joined
- May 16, 2010
- 511
While failing to start my mercruiser 228, I traced the problem to the coil, so far. There is no spark at the coil, so I tried hooking up a lead from the battery, directly to the coil and still no spark. I converted my points ignition over to electronic so there is a black and red wire coming from the distributor which are hooked up to the - and + of the coil, repectively. there are also two grey wires going to the - side of the coil and a wire coming from the slave solenoid along with a second wire from the wire harness that goes to the + side of the coil.
Any ideas what Im missing? The coil is brand new.
