No spark Chrysler 55 HP
cichlid6348
I changed the starter, both coils and no spark.
It did run 3 months ago.
Best guess on problem ?
Thanks,
Jim:facepalm:
tater76
Re: No spark Chrysler 55 HP
Check out my thread, I just rebuilt my 1973 Chrysler, and put 1985 Force ignition on it. I found alot of issues with my key switch. Check your grounds, all of them! From the neg battery cable to the starter solenoid, etc.. The thread was 1973 coil ignition to 85 force ignition if I remember correctly? It outlines some reasons why you would not have spark. Hope that helps?
wickware
1. Magneto/Points , CD or etc ignition system?
2. What is the indication of no spark?
3. Have you checked for spark with the plugs removed?
4. I?m trying to see if it has no spark or not starting??
Good Luck!
jow
