starcrafter65
Thread starter- Joined
- Jun 9, 2009
- 645
I have a 3.0 Merc - no spark - battery has been checked and is fine. I have voltage to the coil but no juice coming out of the coil. When I crank the starter I am getting 9.8 volts at the terminal of the coil to ground. Battery is 12.8.
Can the coil be bad? No moving parts but then again solenoids are sealed too and they need replacing:facepalm:
Coil probably 20 years old and has mild surface corrosion. I did check the Ohm - 3 across the terminals and 10k across the ground - which should be normal....
Thanks electricians!
