MrHProblems
Thread starter- Joined
- Jun 2, 2025
- 34
This is going to be a relatively long one I believe.
Information:
1996 Bayliner Capri w/ 3.0LX Merc.
I stored the boat for the winter and came back this season to take it out on the lake and BAM, crank no start.
I narrowed it down to no spark, replaced the distributor, rotor, cap, etc(made sure to set the timing, it’s 8° before)
replaced the ignition coil,
bypassed the kill switch temporarily,
unplugged the shift disrupter( connected the 2 wires on the harness to each other),
Check continuity of all the plug wires,
Made my own EST-Coil wire harness because the factory one appeared to be bad,
New spark plugs,
Tach is unplugged from behind the gauge cluster,
All fuses are good.
I also tested to see if I’d get spark directly from the coil, no spark. I have 12 volts entering the coil via the purple wire that is in the same connector as the grey wire, I also have 12 volts leaving the coil through the harness to the distributor, as well as through the plug wires going from the coil to the distributor.
At this point I have no clue what else it could be.
Information:
New spark plugs,
All fuses are good.
