No spark from coil
ejput
I have a 2001 Merc 5.7 EFI/TBI. Had a no start issue this summer, got it back on land and started working on it. A few days ago I replaced the coil and coil wire. I did have to reposition distributor housing shaft and finally had it running. Today I went to dynamic time the engine, grounded the ignition base timing wire (purple/white, I believe that is what it's called) and went to start engine, no start. Rotated the distributor housing in different directions, still nothing. I then put a spart tester from coil to cap and had not spark. Coil is new so there must be something else going on. Any thoughts?
Bt Doctur
Usually the ecm controls the timing? all you do is install the rotor in its a marked position and the computer does the rest
Need the full engine number to determine the correct manual number
This is free to read
ejput
there was no marked position, I had to get the #1 cylinder to TDC on the compression stroke then line the rotor up with the number one plug and micro adjust from there to get it strated.
Bt Doctur
if you have the HVS type dist(flat cap) ,there is a marked position
nola mike
Here you go
Fun Times
2001 Merc 5.7 EFI/TBI and I went to dynamic time the engine, grounded the ignition base timing wire (purple/white,
Being that you have 2001 year engine model EFI that would (should) still the MEFI ECM controlled engine model you wouldn't be grounding out a purple/white wire and if that is the case, I'd have to believe at minimum, you blew a fuse somewhere possible depending on what actual wire you grounded out as that method should only be used on most V6 and V8 Carbureted Models (Thunderbolt V Ignition) systems.
In the following linked guide about halfway down covers how to time the V6 and V8 EFI Models (EFI Ignition) but using a needed service tool to help get you into service mode....
Or to bypass buying a tool then the following way to do that can be found inside the next following linked guide by Dave_N via jumping pins A & B of the data link connector where you'd plug a scan tool in...,
  • Like
Reactions: muc
