long story- I have a 1990 force 90hp on a Bayliner Capri 1800 that I bought last month. Took it out first time and ran like bat out of hell all the way down the lake. I bounced across a wake when I throttled back for a no wake zone. When I went to throttle back up the engine was only making about a third of the power. I brought it home found floating sticking on top carb. Replaced needle and fuel pump diaphram. Took it back to lake no help, but noticed this time the tach wasn’t working and I know it did when engine ran good. I changed all three spark plugs no help, under load I pulled each plug wire one by one and hooked back up before moving to next one. Pulling top plug wire made no difference, second plug wire engine ran like crap but did run, pilling third wire killed engine. I swapped top and bottom coils, ran again with exact same results. Stator had a light grey color covering unevenly each coil on stator but the copper looked bright and shinny.
How is do I know if it’s a trigger, stator, or diode?
