farginicehole
- Joined
- Apr 15, 2003
- 482
Okay, I'm starting a new thread to continue my "Evinrude 150 XP won't fire" thread. Each day this week, I've started the motor using the hose and muffs. Every time, there are a couple of cylinders that have no spark. I've determined that it's nothing to do with the plugs or wires, by doing the swaps, and I'm even fairly confident it's not the coils. It is an intermittent problem, and the no spark problem jumps around to different cylinders in what looks like a random pattern. I haven't had a chance to do the resistance check or the peak voltage checks on my stator, as described in my Clymer manual, but plan to a.s.a.p. My question is, since this is so intermittent, is it likely that these two tests will catch the problem (if the stator is indeed the root cause)? I'll gladly replace it or whatever else is failing, but several of these ignition parts are pretty pricey and I don't want to replace anything that doesn't need to be! Expert advice would be greatly appreciated - thanks in advance!
