no spark on 1979 merc 140hp
jimbo8489
hey guys, I was wonderin if anyone had any ideas for me. I have a '79 Inline 6 140 horse with no spark. i took it ot the local mercury mechanic and he told me there was a switch box that was bad. At that time only three of the 6 cylinders had spark. after replacing the switch box there is now no spark on any cylinder and the guy said that the readings on the stator are all wrong. I checked it out myself and found the resistances all wrong also. So i put a new stator in myself, but still no spark. If anyone has some advice I would really appreciate it. Thanks, Jim
Laddies
Banned
Re: no spark on 1979 merc 140hp
Have you disconnected the blk/yel wire from both boxes, have you disconnected the 2 yel wire from the rectifier, have you disconnected the bias wire between the switch boxs( a bad bias in one box can destroy a new box with the exception of CDI boxes)
jimbo8489
where does the blk/yel wire come from, the trigger or stator? why would disconnecting the rectifier do anything? and is the bias wire the blk/white wire that goes between the two switch boxes?
jimbo8489
thanks chris but just one more question. on the link you sent me to at the top of the page it says disconnect the blk/yel wires from the PACK. do they mean the coil packs er wat?
